Where do the trans and t-case breather lines clip into?
I must have forgot to clip them back in after the rebuild. They have a christmas tree plug and go somewhere near/behind the passenger valve cover... but I can't find a hole anywhere!! Does anyone know exactly where they go? Pic would be A++
Also if you have any tips or ideas on breather extensions or new tubes altogether, it's a mod I'm interested in. It would be cool to replace all the lines, and extend them all up to the same spot in the engine bay, but I'm not sure if the banjo bolt on the tcase or trans is accessible.
If you want to raise the vent tubes you can get TF167. That kit has push lock air line fittings so you just use tap into the OE line (not at the banjo bolt). Like > www.discovery2.co.uk Breathers
L8 has it > https://www.lucky8llc.com/products/t...-breather-kits but if you have a hydraulic/air line (brake/suspension) fitting place near you they will have very similar fittings. There is really not much to the kit.
I don't know the diameter of the OE breather hose, but it sure would be easy to find the parts to this kit. Something like this is a sure bet these fittings are out there > https://www.summitracing.com/parts/a...4300/overview/ and this https://www.summitracing.com/parts/a...4400/overview/
No doubt (see my edit) it took like 2 minutes to find fittings at Summit/JEGS. I know for a fact I would not spend $100+ on a kit when there is way less than $50 worth of line and fittings to do the TC, AT , and both axles.
> https://www.summitracing.com/search/...rder=Ascending
> Vibrant Performance One-Touch Pneumatic Vacuum Line Fittings | JEGS
And the RED should add at least 5 Hp
> Firestone 0938: Air Line Tubing | JEGS
rcrosby
Oct 2, 2018 05:47 PM
falcontech
Feb 5, 2008 04:04 PM
