Where does Crank Position Sensor plug into on top
Old 07-04-2018, 07:42 PM
mr. choodles's Avatar
Default Where does Crank Position Sensor plug into on top
Replacing my CPS today. Disconnecting the CPS from the top socket was such a pain. As it always happens, I broke off a small plastic piece of the top socket, so my CPS is not as securely attached as it once was. Questions:
1. Where does the top of the CPS plug into? It is some sort of wire.... Part # anyone?
2. How hard is it to replace that wire?
Attached Thumbnails Where does Crank Position Sensor plug into on top-screen-shot-2018-07-04-8.31.08-pm.png
Old 07-05-2018, 03:40 AM
JUKE179r's Avatar
The CPS wiring goes back to the engine control module (ECM).
The wiring has a shielding on it that has to be placed in but you can get a replacement connector at RockAuto for $18...
https://www.rockauto.com/en/moreinfo...786096&jsn=253
Old 07-05-2018, 08:17 AM
Thank you! How much of a task is to replace that wire? I presume I need to take out a **** ton of parts from the top end....
Old 07-05-2018, 10:30 AM
zuke's Avatar
It wraps over your transmission to the passenger side. Its a pain.
dparham
03-15-2018 02:28 PM
hrhoward
03-22-2017 06:50 AM
kmyer74
05-29-2011 10:20 AM
Bryan H
01-19-2011 09:20 PM
LuvToDisco
04-28-2010 09:06 AM
Quick Reply: Where does Crank Position Sensor plug into on top
