Where does this wire go?
Old May 19, 2018 | 12:05 PM
JoeLena's Avatar
Default Where does this wire go?
Replacing the brake booster and MC in my 2004. This plug, which I guess has something to do with ABS is just hangin' out there. There is no obvious place it should reside anywhere nearby. Where should it be plugged in?
Old May 19, 2018 | 01:03 PM
Best4x4's Avatar
Old ABS wire, you probably have newer style (I don’t care for) that run directly from the hub to the SLABS unit.
Old May 19, 2018 | 01:45 PM
JoeLena's Avatar
Okay, thank you. So not to worry about it?
Old May 19, 2018 | 01:48 PM
OverRover's Avatar
The Female end (BLACK) of the ABS sensor from the hub would have looked like this
Old May 20, 2018 | 01:17 AM
OffroadFrance's Avatar
X1 .................. defo ABS wire. They have now reverted back to the plug and socket type ABS wires as access to the SLABS was causing to much cost and time even without the additional damage problems involved.
Squid4life
Oct 24, 2016 10:17 AM
tcbinaflash
Nov 20, 2011 10:47 AM
s10lowrider1994
Sep 15, 2011 10:07 PM
sloppyjoe
Sep 12, 2009 06:16 PM
tzrover
Jan 12, 2009 08:53 PM
