Where to get low tempurature thermostat?
Old Aug 4, 2025 | 10:13 PM
evil_goat's Avatar
Question Where to get low tempurature thermostat?
I had a black thermostat with no markings or numbers anywhere on the outside that kept temperatures at 187F while driving on the highway and low 190's at other speeds. I never got any error codes about the temperature being too low. I noticed that it was cracking, and got a replacement. I replaced it with the tan/white 180F motorad 439-180 which should be the same part as the "warm weather soft spring" thermostat on atlantic british. However, now my coolant temperature is 203F when warmed up. 15 degrees more. The old black thermostat is marked 78C on the inside. I'm pretty sure the black one I had was the PEL500110 thermostat which atlantic british sold a long time ago since I found an invoice stating the thermostat was replaced with a "warm climate" one from AB and that part number. However the one they sell now is different. Where can I find a replacement for this to keep temperatures the same?
Old thermostat
New one
Old Aug 5, 2025 | 08:07 AM
Best4x4's Avatar
You had one of the good 78C ones! I used the heck out of those until that manufacturer changed their design and simply labeled them as 180F but they were actually stock temp. After that I had to buy the OEM LR 180F Grey units as I couldn't find a true 180F non OEM unit that was truly 180F.
Real OEM 180F on Ebay (Hard to Find)
Old Aug 5, 2025 | 08:26 AM
WaltNYC's Avatar
I've used this without incident (in a P38)....
(fyi, Motorad purchased Stant a couple of years ago)
https://www.rockauto.com/en/moreinfo...&pt=2200&jsn=1
Old Aug 5, 2025 | 02:43 PM
Richard Gallant's Avatar
@evil_goat Hi I have one (78c) you can have for 25.00 plus shipping just pop me a message if you want it.
Old Aug 14, 2025 | 05:49 PM
evil_goat's Avatar
Thank you @Richard Gallant I installed the thermostat you sent and now I am running 20 degrees cooler!
Old Aug 14, 2025 | 06:54 PM
@evil_goat Great!
Old Aug 19, 2025 | 11:27 PM
TNDiscovery2's Avatar
Hey,
Does anyone currently manufacture the 78C thermostat?
Old Aug 19, 2025 | 11:55 PM
@TNDiscovery2 Extinct's inline mode is the simplest. OEM style are pretty hard to find, Amazon or Ebay are generally bad knockoffs that are higher temp.
Old Aug 20, 2025 | 12:44 AM
evil_goat's Avatar
Originally Posted by TNDiscovery2
Hey,
https://www.britishpartsofutah.com/D.../pel500110.htm
This might be it. Even though it says 82C, it is the only one I found online that where the photos exactly match the 78C one I had before.
Old Aug 20, 2025 | 11:09 AM
@evil_goat Yea that is grey soft spring. The black 78C was more typically used for TD5 Diesel engines and hot climates.
Sherlock
May 22, 2023 10:18 AM
thom_77
Apr 21, 2021 10:47 AM
DISCOFETA
Feb 19, 2019 03:16 PM
flyingmada
Apr 26, 2018 06:42 PM
huggi
Oct 12, 2016 11:09 AM
