where is immobilizer located on 95 discovery
I finally got the info in the alarm ecu on the 94-95 discovery. They don't have a spider, they have a starter kill. It's located behind the glovebox on the lower right hand side of the computer. It's a black box with an antenna wire coming out of it. It has two plugs going into it. One of the plugs has 6 wires. To disarm the ecu you cut the two black and orange wires and connect the two wires together. The black and orange wires are the first two wires on one side of the plug. After I repaired all the cut wires and replaced some bad relays the car was restored to the point where all the problems began. The kill box wasn't letting the starter engage. After splicing the two wires the motor turns over and I have lots of spark but still no fuel. The relay for the fuel pump isn't getting the ground signal from the f.i. ecu. I've cleaned all of the grounding points in the car and checked all relays and fuses. If I ground out the negative side of the relay winding I get plenty of fuel pressure to the fuel log. I also removed the fi ecu and checked all the solder points, they're fine. Spike, the car does shift out of park fine. I haven't checked to see if I have brake lights. Antichrist, Thanks for finding the location of the alarm box. I'll keep you posted.
crimson850
07-08-2013 11:25 PM
Roverman7
05-15-2013 12:43 PM
Sbonomo
17
07-30-2012 11:23 AM
Arorra12
04-15-2011 08:57 AM
