whinning transfer case
Old Mar 20, 2010 | 05:56 PM
  #31
Originally Posted by Danny Lee 97 Disco
On a stock DI what all needs to be greased?
Starting from front to back...u-joint, slip joint, u-joint, u-joint, slip joint, u-joint.
Grease all of them until new grease comes out of all four cups and out of the gator that covers the slip joint.
If you run both passenger side wheels up onto ramps it will be alot easier for you to reach everything.
Grease all of these at EVERY oil change and within a day or so after driving through water that is deep enough to submerge the entire underside of the truck.
Old Mar 20, 2010 | 05:57 PM
  #32
Originally Posted by vandev
i just found out that the whining grinding noise is comming from my "well if i buy it" transfer case. It only happens when you are driving over 30 miles an hour and you take your foot off the gas and decelerate. at about 20 miles an hour or when you touch the gas it goes away... You can hear the noise from the transfer case area... Has anyone ever had this happen?driving normal it's quiet...only when you take your foot off the gas...
Thanks Chris
If you start a new thread you will better results.
Old May 19, 2015 | 09:15 PM
  #33
MPDano's Avatar
Great info as I just bought my moms DII and I too can hear a whinning noise. I'm going to grease all the joints listed and see if this makes a difference. Car has been non-op since 2009 and I believe she bought it in 2004. Knowing her, this part part was never in her maintenance schedule.
wavjumpr
Dec 7, 2009 12:15 PM
SantaCruzRoverGirl
Jun 10, 2009 07:37 AM
ragejb
Apr 9, 2007 09:23 PM
darlo14
Jan 21, 2007 12:17 PM
darlo14
Sep 9, 2006 03:48 PM
