White Shepherd VS Blue Devil rear main seal?
Old Mar 6, 2012 | 02:42 PM
urq's Avatar
urq
Default White Shepherd VS Blue Devil rear main seal?
So I ordered some White Shepherd Rear Main Seal from Amazon.com and when I got the package yesterday the bottle says Blue Devil rear main seal?
The invoice says White Shepherd on it?
And looking at photos of the 2 items the bottles look similar but just different names?
Old Mar 6, 2012 | 02:56 PM
They are one in the same, see White Shepherd Rear Main Sealer Repairs Rear Main Seal Oil Leaks | USA SEALANTS | Stop Leak for Oil Leaks, Blown Head Gaskets, Transmission & A/C Leaks. The Blue Devil family of products includes a variety. This particular product (rear main seal) works by "swelling" rubber parts that oil contacts. The effect continues after the product is drained out on oil changes. In the old days, mechaincs would soak things in brake fluid. This is a different product, much safer to use.
Go on line to, gouniversalproducts.com get their number and call them to make sure it is their old rear main sealer.
Old Mar 6, 2012 | 05:17 PM
hhalimi's Avatar
Both are the the same, I got it directly from gouniversalproducts.com and received the blue devil rear main sealer. I didn't even have a rear main leak, just the oil pan bolts were loose.
For some reason I had big hopes, but I don't think the product is that great. I have a small leak from transfer case and put a third bottle when changing the fluid and than some more later, leak is still the same. One of these days will reseal it properly.
Old Mar 6, 2012 | 07:30 PM
The trick with those things is you must drive continually for at least 2 hours.
When I used the oil seal conditioner I put it in right before a 3 hour drive.
Thats was over a year ago now and still no leaks.
Old Apr 10, 2014 | 09:11 AM
collector87's Avatar
Just want to make sure this is the right one.
http://store.gobluedevil.com/rear-main-sealer-00234/
Thanks!
Old Apr 10, 2014 | 09:42 AM
Heard from DiscoMike that this is the right one. Thanks!
Rear Main Seal Leak | Rear Main Seal Stop Leak | BlueDevil
Thanks!
Old Nov 22, 2014 | 12:57 PM
dparham's Avatar
ok I have a question then.... can someone use both their products in the oil? rear main sealer and oil stop leak or are they one and the same? I haven't examined my rear main seal but truck has 100k.. a few little driblets of oil occasionally but nothing Im alarmed about.. valve covers are tight... oil pressure good... temps ok... but would it be ok as a preventative?
Old Nov 22, 2014 | 01:20 PM
04duxlr's Avatar
Oil stop leaks almost always function by swelling up O-rings and seals. They make the rubber a little more pliable and larger so they will tend to stop leaking. You can add some of that but it is my understanding that the rear main seals on these engines aren't prone to leaking. There are 2 cross-shaped seals right next to the rear main bearing cap, called cruciform seals, that usually leak. The stop leak stuff doesn't always fix those.
Old Nov 22, 2014 | 01:54 PM
dparham's Avatar
hmmm.... yeah... I may use them or not... haven't decided... mostly I plan to change oil pump and timing chain.. ect... since an 03 in VIN range, even though it seems to be ok, next maintenance go around... Im at 100k and maybe at 120k Ill do that... to be honest( which I usually am lol) after I did a bunch of maintenance from neglectful prev owner, it has never had any real issue that worried me.. just this and that... I did allot though from window regulator motors to new A/C compressor and cooling system... all new pulleys and fluids lol couple missing caps n covers and BAM! 3 years still in love with it! Oh yeah drive shaft upgrade lol i don't LOVE the oxidizing clear coat however dammit! right about the time my new sweet safari rack I'm building will be installed lol and some $T^&* Bag bumped side adding tiny door ding and scrape... I may install door trim after paint lol
DiscoHan
Sep 25, 2014 06:45 AM
Bryan H
May 24, 2013 02:25 PM
HelenaRover
Oct 30, 2010 07:27 PM
bantham1
Oct 20, 2010 08:41 AM
d.m.disco
Oct 27, 2008 11:58 AM
