White Smoke?
White Smoke?
My possessed 03' Discovery is acting up again. After quite a bit of work (O2 sensors, valve cover gasket, MFA sensor, filters, crank shaft sensor) I thought it was over. Its not. Now I have puffs of white smoke from my exhaust that smells like gas.
No temp spikes or coolant loss but I have two engine codes that pertain to a bad MFA sensor. Two separate issues or both caused by the MFA? Anyone?
Running a paper filter. The exhaust smells like gas...not sweet smelling coolant. Just finished changing the oil a few minutes ago and it was 5.75 qts drained. Doesnt seem to be losing much oil. Its been smoking while running...not a ton but enough to cause investigation. Thanks for any help...
