Who knows cruise control? 2001. Help
#21
I just pulled my clock spring out and tested it this afternoon. Unless it's a mechanical issue, I found that there is no interrupted current from one side to the other. Rotates nicely with no noise at all.So, why my cruise control shuts down when the radio goes on, I'm baffled.
Robert, .. Yes, all buttons on the wheel, along with the air bag wires go through the clock spring. For kicks, do see if the radio being on or off makes a difference in you situation, as it's the same symptoms I have.
#22
In regards to CC troubleshooting, and the "clock spring" that is mentioned. Is that only for the cruise control buttons, or all steering wheel buttons?
Asked another way, if my radio buttons on the steering wheel are working is it safe to assume that the "clock spring" is functioning correctly?
On my CC I get the light on the cluster button but when I pull the button on the steering wheel I get nothing. No click or noise at all. Radio controls on the steering wheel work.
So if your horn is working and you don’t have any SRS codes and even the radio controls work, but no cruise, then yeah I bet that part is fine.
I think Best 4x4 had the best rundown of what to inspect in troubleshooting:
- Under hood components
- Brake switch
- Clock Spring
#23
#24
#26
Yeah it’s funny as it will hold if I push into it, but it won’t on the suction side. Also, if I squish it WAY down, it will hold the vacuum, but not for the realistic level (like in the pic above).
I’m going to order one from Atlantic British I guess, but the darn thing is $110. Oh well.
I’m fairly certain this is it as I hear a click from the controller in the footwell, so everything in the cab must be working correctly.
#27
#28
#29
UPDATE:
Removed my radio and sistered up a ground wire to the factory ground on the radio wire harness. Tested and thought for a second that this did the trick, but no. A couple weeks later, today, I went ahead and cut the factory ground off the radio harness, leaving just the new ground I had sistered up. That was the issue! All works now.
So, if you have this issue, then cut the factory harness ground wire that goes wherever (Obviously to the same grounding point as the cruise control), and splice in an all new ground to that plug.
Happy camper.
Happy camper.
#30
UPDATE:
Happy camper.
Happy camper.
Evan5291
11-21-2017 07:59 AM
southfloridadiscoII
06-28-2009 11:03 PM
