wierd codes from my disco 2
Old Nov 22, 2010 | 09:04 AM
novadisco2's Avatar
Question wierd codes from my disco 2
pluged in my scanner on the week end and came up with some codes, 31, 0032, 108, and 00121. They Appear to be land rover specific, and came up on the new snap-on verdict scanner under land rover. I can't find code deffinitions on them in mitchell or the rave manual. anyone else run into this?
Old Nov 22, 2010 | 05:35 PM
Fireman's Avatar
Sorry Nova, I don't have much for you. The first 2 look like O2 sensor codes. The third seems to be a MAP code. You are right, there doesn't seem to be anything in RAVE.
Old Nov 22, 2010 | 08:12 PM
novadisco2's Avatar
what's weirder is if you go with global obd2 there are no codes....but the ses light was on, I cleared the codes after I looked at obd2, and so-far they've stayed off.
Old Nov 23, 2010 | 08:19 AM
Fireman's Avatar
The generic descriptions are:
P0031 = HO2S Bank 1 Sensor 1 Heater Circuit Low
P0032 = HO2S Bank 1 Sensor 1 Heater Circuit High
P0108 = MAP/BARO Circuit High Input
P0121 = TPS/Pedal Position Sensor A CKT Range/Performance
Let's just hope they don't come back. If they do, you may want to look at the TPI.
Old Nov 23, 2010 | 10:04 AM
How is the truck running? You might want to have your charging system checked, quite often when the voltage is below 13.6 volts the ECU's will throw weird codes.
Let us know what you find.
Old Nov 23, 2010 | 08:44 PM
novadisco2's Avatar
Thanks fireman and mike, truck seems to run well, just finished your 60k service list, as well as the brakes, front springs, exhaust leaks, a hub, multipal grounds and a battery. (and a massive cleaning and undercoating) I briefly checked the alternator with my avr tester, it's output was exactly 13.6 volts. I think I'll pull the alt off the spare frame and build it just in case, the one on the driver may clean itself up after I start driving it. (keep in mind the trucks been in storage for 4ish years)
Thanks Pat
Kiwijeff
Aug 18, 2015 08:22 PM
tre soli
Jun 14, 2014 06:06 PM
rholtporsche
Aug 27, 2009 09:12 AM
Doral300sc
Feb 25, 2006 11:32 PM
Randy Lover
Sights N Sounds
Aug 6, 2005 07:39 AM
