Sponsored by: CARiD
93 disco, wierd heater noise.
Old Aug 17, 2015 | 06:05 PM
Kiwijeff's Avatar
Default 93 disco, wierd heater noise.
Is it normal for the heater to sound like its got a box of baby birds in it?
Seems to happen mostly when turning corners. Apart from that, heater works fine.
Anyone have same issue, and know what it is, how to fix, etc.
Thanks, Jeff.
Old Aug 17, 2015 | 08:17 PM
june82000's Avatar
Mouse nest in the fan box? Does it do it with the fan off?
Old Aug 18, 2015 | 01:06 AM
Joe Btfsplik's Avatar
sounds to me like your heater motor has some bad bearings or bushings. I took mine out on my D2, carefully removed the fan and oiled the motor bearings. Voila! quiet as a mouse. Or, it could be full of junk, paper wrappers, foam, other crap that falls into the intake. Check this post out; https://landroverforums.com/forum/di...r-motor-51337/
Old Aug 18, 2015 | 01:53 AM
Kiwijeff's Avatar
Thanks guys, I'd say its something along the lines mentioned. I'll take a look in the morning.
I'll go check the link.
Old Aug 18, 2015 | 01:58 AM
Kiwijeff's Avatar
I just checked the link, I knew I should have searched first, before starting the thread. It was late, and I was being lazy.
Old Aug 18, 2015 | 02:20 AM
By the way, the reason it squeaks worst when you drive around a corner is that the fan is basically like one of those toy gyroscopes, as it spins it wants to stay in the same plane, as we corner we force it out of that plane and it stresses the bearings. Squeak, squeak!
Old Aug 18, 2015 | 06:58 AM
drowssap's Avatar
you need to replace the blower motor, take about 20 minutes you can get a good used one from either of the links in my sign.
Old Aug 18, 2015 | 06:20 PM
Kiwijeff's Avatar
Thanks guys, I've been reading up, and I'm almost ready to go out and dig into it.
I'll try cleaning it out, and greasing the bearings, and see what happens.
Old Aug 18, 2015 | 06:28 PM
june82000's Avatar
You can try to lubricate the bearings, but the sound will be back, guaranteed .
Old Aug 18, 2015 | 08:22 PM
Kiwijeff's Avatar
I took to long reading up about this, and it started rainnin. No room in shed, so has to be done in driveway.
Hope to get back out there soon.
kavik
Dec 26, 2008 10:48 AM
msk2503
Nov 19, 2008 07:38 AM
dallasrover
Apr 15, 2008 05:40 AM
jh063078
Feb 19, 2008 10:20 AM
