wierd noise from abs modulator box
Old Dec 26, 2008 | 08:15 AM
kavik's Avatar
Default wierd noise from abs modulator box
Tried a search, didn't find anything-
2003 discovery, v8, w/ ace. I have a very,very soft noise, almost a beeping or an electronic hum, coming from the abs modulator box. Follows a pattern of about 1/2 second on, then 1/2 sec off, repeating. This is continuous - if the engine is running, off, even if the key is removed. Having no brake problems, lights, or battery issues. Any ideas?
Old Dec 26, 2008 | 09:14 AM
Darover's Avatar
Default RE: wierd noise from abs modulator box
Don't worry about it, can't technically explain it, but its normal. Mine's been doing it forever.
Old Dec 26, 2008 | 10:43 AM
04BluDisco's Avatar
Have similiar noises....... never had any problems with the brakes, ABS, etc. I attribute it to a disturbance in the force.... and have never found a 'fix' for it, or even reasoning as to why it needs to be fixed.... wierd
J
Old Dec 26, 2008 | 10:48 AM
I believe that there is a TSB on this and that the dealer can remap the SLABS unit to make it stop.
Itcan run the battery dead if not driven for awhile.
Kiwijeff
Aug 18, 2015 08:22 PM
msk2503
Nov 19, 2008 07:38 AM
dallasrover
Apr 15, 2008 05:40 AM
jh063078
Feb 19, 2008 10:20 AM
