Will badly failing cats cause misfire?
Old Jan 22, 2016 | 12:10 PM
schwaggy's Avatar
Default Will badly failing cats cause misfire?
My cats are known failing (sound like rattle cans) and I recently had 2 instances of cylinder 6 misfire. Cleared the codes and been ok since.
What cats are folks going with these days - just welding in Flowmaster cats only, or perhaps the entire set of pipes and cats from the likes of Magnaflow?
thanks!
Old Jan 22, 2016 | 02:58 PM
Alex_M's Avatar
Bad cats won't cause misfires, but misfires will cause bad cats. I've just welded in the flowmaster spun style. I did headers and larger diameter pipe at the same time and I'd really recommend it if you've got the ability. I did 2.5" pipe in the y-pipe and 3" single out the back and all mandrel bends and it made a noticeable difference in the 2 miles before my crank position sensor went out. I'm working on that today.
If you just cut out the factory cat and weld in the universal style then the pipe won't line up just right and you'll decrease flow, but if you're not worried about that then that will work fine.
Old Jan 24, 2016 | 09:44 PM
jfall's Avatar
Bad O2 sensors will cause misfire.
Bad speed sensor.
Bad wires.
Bad plugs.
Sticking valves.
Failing fuel pump.
Bad gas.
For codes
http://enginecodemaster.com
pdowning6
May 12, 2012 10:30 AM
gmscando
Mar 28, 2011 11:51 PM
Disco Den
Mar 28, 2010 12:42 PM
elboy0712
Mar 16, 2010 07:25 PM
epeteha
Jun 9, 2008 05:27 PM
