Will this damage the power steering pump?
Old Jul 28, 2010 | 11:55 AM
Bryan H's Avatar
Default Will this damage the power steering pump?
If I run the engine with no fluid in the power steering pump, will it be damaged? I don't intend to drive the vehicle (or turn the steering wheel), but I would like to start the engine, but the high pressure hose from the power steeting pump to the cooler won't be hooked up (It's damaged and I need to buy another one. But at $125 for a new hose, I want to make sure the used engine I'm installing will run before spending more money).
Old Jul 28, 2010 | 12:52 PM
Bundu's Avatar
Banned
The fluid lubricates the pump, do you really want to run it without fluid? That's up to you, I would not.
What's wrong with the hose? I had mine repaired at a place that makes up hydraulic hoses for all kinds of machines, it cost me pennies compared to a new one.
Old Jul 28, 2010 | 03:20 PM
Bryan H's Avatar
The hose could probably be repaired (it's just damaged threads), but it's a timing issue for me. I'm renting a car during the motor swap, so the more time I take to get little things fixed, the more the rental costs. I'm going to work on the threads tonight and see if I can fix them. They're M16 1.5p, so dies aren't readily available (the only one I found locally was in a set at Harbor Freight that costs $75).
Old Jul 28, 2010 | 04:54 PM
Bundu's Avatar
Banned
Check at DAP, they go for $75. http://www.dap-inc.com/
Yeah, metric dies are a bitch to get. I pulled a fast one on HF, I needed to clean a thread and got the set, used it for less than 5 minutes and took it back. Not honest, but heck sometimes ya gotta do what ya gotta do.
Old Jul 28, 2010 | 05:05 PM
Bundu's Avatar
Banned
Try this guy for a used part:
http://www.landroversonly.com/forums...isco-ii-41361/
johnnyjohnny
Sep 26, 2019 09:37 PM
joshjellel
Feb 16, 2015 10:53 AM
Sandman0306
Dec 15, 2012 03:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
