Will not go into gear
Old Oct 11, 2009 | 12:08 PM
jmccollister's Avatar
Default Will not go into gear
My Disco 1 is only sporadically going from park to drive. I popped the top off to see if I could fix this. I can get it to still only go sporadically. Do you think there is a wore out spacer or the cable is stretched out? any ideas I feel this is an easy fix, my repair manual however sux!!
Old Oct 11, 2009 | 12:11 PM
sloppyjoe's Avatar
brake switch.
look behind your brake peddle arm under the dash.
little black switch that releases the tranny when you press the brake.
cost is about $20-$25 bucks and takes less then a minute to replace.
Old Oct 11, 2009 | 06:01 PM
http://www.autozone.com/autozone/cat...&parentId=57-0
GodSavetheQueen
Aug 19, 2013 07:01 AM
green-lantern
May 16, 2013 01:41 PM
KBW
May 23, 2010 03:35 PM
donaldaltom
May 23, 2010 04:28 AM
mdl4usc
Mar 6, 2007 03:27 PM
