Window breaks .. Do you know the solution?
Old Feb 27, 2018 | 08:44 AM
honghanbyul's Avatar
6th Gear
Default Window breaks .. Do you know the solution?
The driver 's window is broken.
But. There is movement.
Guessing that something could not move
Can I fix this by myself?
A professional company said that the plastic broke.
Can I get information about this part?
Old Feb 27, 2018 | 08:52 AM
Saturnine's Avatar
Like, broke in as the window won't roll down?
Old Feb 27, 2018 | 09:54 AM
CollieRover's Avatar
You need a new window regulator. They wear out, and it is a do it yourself job. You'll want the regulator and extra clips/hardware that holds the Door card on. You'll need a screwdriver, and a set of plastic panel separators to get the door card popped out and avoid scratching the paint.
The job takes patience, and a bit of trial and error to fit, but it is doable.
Old Feb 27, 2018 | 12:15 PM
Frank4's Avatar
If the shop tells you that it is a plastic piece that’s broken it’s probably the roller that rides in the track. Yes, you can fix this yourself.
Old Feb 27, 2018 | 12:31 PM
Sixpack577's Avatar
The rollers are available individually, someone on this site sells them.
Old Feb 27, 2018 | 09:59 PM
Lisa Bunch's Avatar
It could be rollers in the motor. My regulator is fine, my motor runs fine. Need to take it apart, there's a video on YouTube.
Old Feb 28, 2018 | 06:49 AM
Sixpack577's Avatar
The motors don't have rollers in them, they have gears.
The window track has plastic rollers/wheels.
When the rollers break, the track moves slowly, or binds and moves until it jams, or can't move at all.
The electric motors wear out and gum up over time.
The window will go up and down freely, but slowly, until the motor can't move it any more.
Replacing the motor, track, or just the rollers is a very easy job.
calebbo
Oct 12, 2011 09:54 PM
Fireman
Oct 25, 2010 07:00 PM
lipadj46
Nov 25, 2009 04:56 PM
DIMISA1977
May 6, 2005 04:22 PM
