Window leak?
Old Oct 9, 2021 | 07:24 PM
anbran's Avatar
Default Window leak?
I have a 2002 D2 and I noticed a wet spot on the headliner near the Alpine window on the drivers side. I pulled the trim away from the rear sunroof and looked in and around. It looks brand new in there and the drains are intact with no signs of water. I'm thinking that perhaps the alpine window had developed a leak?!
The leak is not above the headliner (fiberglass framing) but appears to be coming from the side (near alpine window). Its just the headliner itself that is wet...
Any ideas?
Old Oct 9, 2021 | 08:00 PM
Extinct's Avatar
The OEM sunroof pan design is crap, is not sealed. Leaks at the motor mount, sunshade mounts, sunshade latches, and at the corner fittings where they are glued to the pans. Headliner has drain channels molded in to channel water down to the sides. Pull the headliner out and drive it two weeks in the rain with the headliner out and you will find all the leaks.
Quinn519
May 8, 2021 03:37 PM
lndrover@carolina.rr.com
Jan 17, 2020 11:20 AM
Cosmic88
Sep 30, 2011 09:01 AM
oneohsix
Freelander
Dec 20, 2008 06:09 AM
PITTDISCO
Appearance & Camping Set Ups
Jun 21, 2008 04:29 PM
