Window regulator or motor?
Old Sep 19, 2014 | 06:20 PM
abran's Avatar
buy a used one, I just happen to have a few...
Old Sep 19, 2014 | 10:50 PM
mattmo78's Avatar
So, just for future reference, how much is a used window motor? 99 D2, front driver side. Shipped to 74055.
Old Jan 27, 2015 | 05:54 PM
JimmyTomahawk's Avatar
mattmoto78,
What ever came of this situation? My drivers side window just did the same thing, all of the symptoms you describe sound like mine. Wondering what to anticipate ordering, how much and what to plan on with R/R...
Old Jan 27, 2015 | 08:22 PM
mattmo78's Avatar
Originally Posted by JimmyTomahawk
mattmoto78, What ever came of this situation? My drivers side window just did the same thing, all of the symptoms you describe sound like mine. Wondering what to anticipate ordering, how much and what to plan on with R/R...
The motor in mine had a stripped gear. The regulator seemed fine, but I went ahead and replaced it also. Got a used window motor, installed it, and it works like a charm. Send Abran a PM and see if he has any motors for you.
Old Jan 28, 2015 | 04:39 AM
OffroadFrance's Avatar
If it's the original regulator it's almost sure to be that. Motors are good and rarely burn out. Changed my drivers (LHD) regulator recently and bought a new aftermarket unit off Ebay (cheap as chips £16=$24 ) and fitted that with the original motor, now it's as good as gold. The motor cutout point relies on resistance of coming to the end of the gear rack which causes it to cut out, very crude but effective. The gear rack centre pivot wears drastically and the motor gear over runs the end of the rack and the window stays down. There are other causes but this is the most common.
The other problem is the small plastic/nylon rollers in the regulator fall apart and the window drops when they come out of the track. Another common occurrence. hey ho, most are 10-15 years old and have been well used and subject to vibrations for that time, not bad to last that long.
Old Jan 28, 2015 | 11:51 AM
ralphobell's Avatar
The gears inside the motor will bust in 1/2. Usually caused by the regulator going out. These trucks are 10 to 16 years old. Lots of plastic gears in these things...they have become brittle over time and will surely brake soon. I have replaced both front regulators and motors.
Old May 31, 2015 | 11:48 PM
chris143007's Avatar
Does anyone sell the round rubber gear/sprocket that sits inside the motor casing? Abran, do you have good used motors for sale? I'm local and may want to pick one up tomorrow.
RedAustinIX
Aug 10, 2020 11:43 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
darrenh1975
Aug 5, 2007 03:41 PM
zachbraff
Jul 18, 2005 12:57 AM
