Window regulator wires
Old Sep 5, 2017 | 02:59 PM
LR03NJ's Avatar
Originally Posted by Sixpack577
I hope it's right.
I just unplugged the factory harness from the stock motor. Then opened the new one to find a plug on it.
I bolted the new motor to the new track, posted the question, and went to bed.
Hopefully I can just plug it in further up the harness, I'll find out tonight.
Thanks
Yah, I hope too it right. The motors are similar but the sliding connectors I had the problem once. When installing the scissor mechanism, start with the 2 bolt from the shorter metal part and the rest will be easy. Move the glass all the way up and secure it with a clamp with rubber grips on top of the window door frame to hold the glass from falling inside. Once you secure the 4 bolts that hold the motor, lower the glass slowly until it reach the bracket and bolt it down.
Old Sep 5, 2017 | 03:01 PM
Sixpack577's Avatar
That sounds easy...it'll never work, lol.
Old Sep 5, 2017 | 03:03 PM
LR03NJ's Avatar
HAHAHA! I did 3 in one day. I think, I still remember the steps.
Old Sep 6, 2017 | 08:11 AM
Sixpack577's Avatar
Easiest job I've done in a while.
If dummy me would've traced the factory harness another 6 inches into the door, I would've found where the short harness to the factory motor unplugs. Which is where the new motor plugs in.
It was late, I was tired...and you guys came through again!
Thank you for the help!
RedAustinIX
Aug 10, 2020 11:43 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
garover
Mar 28, 2005 08:44 PM
