Window won't go down
Old Oct 9, 2017 | 09:41 AM
Vai2kdna77's Avatar
Default Window won't go down
My disco 2 drivers side window won't roll down. I have put a meter on it and when I press the button I get voltage but no action. Is the issue the window motor or the scissor piece that holds the window itself? How can I tell? I am ready to burn this thing to the ground. So pissed!
Old Oct 9, 2017 | 09:43 AM
Kdo58's Avatar
Window regulator eBay has them for $26.
Old Oct 9, 2017 | 11:40 AM
mln01's Avatar
Can you hear the motor trying to turn? In my case it was the motor. The new one was $34 shipped from Lucky8.
Old Oct 9, 2017 | 11:53 AM
OffroadFrance's Avatar
The whole regulator and motor is as cheap as chips. If you are getting power to the motor plug it's either the motor kaput or the regulator or both.
Old Oct 9, 2017 | 11:54 AM
wjsj69's Avatar
Calm down, you bought a truck that will need maintenance like this. You will probably be replacing all 4 window motors, regulators("scissor piece"), locks depending how long you have your truck. These door mechanisms are the easiest to replace that I've ever experienced; very simple, but they only last so long. I suggest you replace the whole assembly so you don't have to mess with it again. Look at a vid if you're having trouble.
Old Oct 9, 2017 | 12:28 PM
Sixpack577's Avatar
The regulator probably has a broken wheel, binding and preventing it from going down.
It's an easy fix.
Old Oct 9, 2017 | 01:07 PM
AndersonD's Avatar
It's an easy fix.
Also, on this forum, there is a thread about that issue: https://landroverforums.com/forum/di...asy-fix-76470/
That might be helpful.
jamieb
Aug 6, 2013 10:17 AM
jbunner
Jun 5, 2012 08:48 AM
Newfoundlandrover
Oct 2, 2011 06:51 PM
SC Rovergirl
May 15, 2010 07:06 AM
jw928
Feb 6, 2010 06:51 PM
