Windscreen wipers
Old Feb 22, 2009 | 06:57 AM
danperrett's Avatar
Default Windscreen wipers
Hi,
I've just bought a 93 Discovery and I've notices its got a few issues.
The main one is that the wind screen wipers don't work and seem to constantly blow fuses. This one could probably be a loose wire somewhere but I'm wondering if this is a typical fault for discos? anyone have any ideas?
Cheers.
Old Feb 22, 2009 | 08:07 AM
Check your under dash fuse panel for loose wires coming out of the back of it.
I would say it is a back switch but that should not blow fuses, I say that you have a short somewhere, that will be very hard to find.
Wait a minute, is the wiper motor any good? If it is seized when you turn the wipers on the motor will get hot and draw to many amps and blow a fuse.
Pull the wiper motor out of the truck and bench test it.
Old Feb 22, 2009 | 08:50 AM
AK Rover's Avatar
Is the fuse blowing immediately when you turn the wipers on or is there a delay? A delay would indicate that the motor is overheating like Spike suggested. If the fuse blows immediately then you have a short somewhere in the system. For a short I would check the wiring at the switch first. Any place where you have physical movement is a prime candidate fr a wire to short out.
Where are you located? Here in the states the Discovery didn't show up until 94, that's why I ask. More curiosity than actual need to know to help with the problem. How many miles on the vehicle? Any ideas about the maintenance history?
Old Feb 22, 2009 | 01:32 PM
danperrett's Avatar
I've just managed to fix it, may be tempory.
I took the wipers of and squirted a ton of WD40 down the wiper spindles. This seemed to loosen them up sufficently enough for them to start moving and not blow a fuse. so it must have been a load issue.
Cheers.
for you help anyway
Sally1971
Dec 27, 2012 07:32 PM
ando98
Jun 16, 2012 08:36 PM
Camdisco24
Dec 22, 2008 12:35 PM
jh2
Nov 13, 2005 06:57 PM
englishboyonice
Aug 18, 2005 07:23 PM
