windshield wiper problem
Old Dec 20, 2009 | 03:49 PM
Classklown90's Avatar
Default windshield wiper problem
Ok so nj had some bad snow this weekend and at one point I had turned my wipers on and they were stuck from the snow so I guess I pulled on the driver side one or something because now it won't move? The passenger one works but the driver only like twitches, trys to move but dosent. Anyone know what's wrong?
Old Dec 20, 2009 | 04:31 PM
First whenever it snows or you have ice on the windshield you must make sure the wipers are not frozen to the glass or have to much weight on them, you will burn up the wiper motor.
But your problem is easier.
Tighten the wiper arm nut.
Old Dec 20, 2009 | 04:37 PM
O ok thanks and yes I know they were pulled up its just I was cold and lazy. How do I acces the wiper arm nut? When I lifted the hood I tried to find a way to remove the plastic covering the wiper parts but idk how
Old Dec 20, 2009 | 04:40 PM
Close the hood, look at the wiper arm, at the base, there is a black cover, pop it off, tighten the nut, put the cover back, done.
15 min.
You can put a lock washer on the nut to keep it from coming loose again.
Make sure your wiper arm is in the right spot before you tighten the nut.
Old Dec 20, 2009 | 05:13 PM
Awesome thank you
Old Dec 20, 2009 | 05:50 PM
Robwsup's Avatar
I did the same thing.
It blew my fuse, easily replaced, but other vehicles I've owned fault, then reset themselves.
Old Dec 20, 2009 | 06:09 PM
yea well it was the nut, works fine now thanks again
philipisland
Feb 4, 2013 07:13 PM
mojoboots
Oct 28, 2012 10:58 AM
Monty
Jan 27, 2008 02:19 PM
Dublz
Sep 14, 2007 12:36 PM
Oldracer
Dec 25, 2006 04:46 PM
