Windshield Wipers Overextend Normal Range
Old Mar 21, 2012 | 01:54 PM
mwyoung's Avatar
Default Windshield Wipers Overextend Normal Range
The windshield wipers on my 2000 Discovery II are overextending their optimal range. Another way to describe it is that they are "sloppy" and have excessive play.
I have removed and readjusted the each of the wiper arms several times and have verified that they are securely bolted down. No matter how I position them they either come to a rest on the lower windshield surround or they slap against the driver's side A-pillar when operating.
I've checked the workshop manual and it isn't clear if it is possible to adjust the motor or the linkage.
Several unsuccessful searches of the archives and I'm finally asking for advice. Anything you all have to offer is appreciated.
Thank You,
Old Mar 21, 2012 | 08:04 PM
Start with new wiper arms and lock washers on the wiper arm nuts.
Get a pair of these.
Wiper Arm - Front (PRC8236 Same Fit As Part # DKB102710) - Land Rover wiper blades\washers from Atlantic British
The are a exact fit and you can then buy your wiper blades anywhere, including the gas station.
Old Mar 21, 2012 | 08:08 PM
jafir's Avatar
These are probably a better deal, because they come with the caps too. The wipers they come with are pure trash though.
Rovers North - The Source for Classic Land Rover Parts - WIPER BLADE CONVERSION DISCOVERY II FRONT
Old Mar 21, 2012 | 08:12 PM
Damn that is a good deal!
Old Mar 21, 2012 | 08:16 PM
jafir's Avatar
If the linkage actually is worn out, I think you have to get the entire motor.... I think.
You might make sure the entire assembly is still securely bolted down though.
Old Mar 21, 2012 | 08:27 PM
mwyoung's Avatar
Thanks for the suggestion of new arms, washers, and lock nuts; however, the issue has nothing to do with wiper arms or worn attachment points. The connection between my wiper arms and the attachment posts is solid.
The play is significant enough that the wipers when resting on the lower windshield surround will still make contact with the a-pillar. I'm pretty confident it's play in the linkage. Anyone know if that's adjustable or if you can replace the linkage separate from the wiper motor? An entire motor assembly from Rovers North is $240, so I'm hoping someone has insight on adjusting or replacing just the linkage.
Old Mar 23, 2012 | 05:27 PM
mwyoung's Avatar
Problem solved! Finally removed the plenum air intake to get at the wiper linkage and motor. Two of the three bolts holding the wiper motor motor to the mounting plate were missing, and the third was loose. The two missing bolts were just rolling around under the plenum and were easy to reinstall (this time with Lock Tight).
Old Mar 23, 2012 | 05:37 PM
jafir's Avatar
Good job! Always nice not to have to buy parts!
I might add that I did suggest looking at that
Old Sep 14, 2013 | 05:15 PM
Eric R. Shelton's Avatar
Not to resurrect a dead thread (though that's exactly what I'm doing), but I'm having this exact problem. I'm hoping for a similar fix, so now I have to ask- what's the plenum air intake? How do I get at it remove it and check the linkage? Or where should I get a guide to help me with this stuff? My wife loves her LR3 (recently bought it used), but she's not crazy about it being useless on rainy days. Gotta fix it if I'm going to maintain domestic bliss. Thanks!
greenfish
Oct 3, 2018 02:36 PM
yevgenb
LR2
May 4, 2009 12:21 AM
JBEGIN
Dec 23, 2008 02:08 PM
DiscoGravy
Jun 26, 2006 03:26 PM
brianwi11iams
Jul 20, 2005 02:36 PM
