Wipers stopped working
Old Nov 26, 2014 | 01:42 PM
Andy2Rover's Avatar
Default Wipers stopped working
Hey Guys,
My 2000 D2 front wipers quit working today. Happened suddenly while driving. Windshield washer still works. Fuse #19 is good. I think it may be the relay (if a relay exists for the front wipers??)
I'm getting confusing info about a front wiper relay. Rave says it's in the passenger compartment fuse box but doesn't give exact location. I searched the forum, and reference was made to Relay #7 in the engine compartment fuse box.
Can someone tell me if there is a front wiper relay, and if so, where it is located?
Thanks!
Andy
Old Nov 26, 2014 | 04:26 PM
Andy2Rover's Avatar
Well, after further review it seems like the wiper motor is working. I can hear it come on when I activate the wiper stalk. So I think my nuts are loose.
Check your nuts everyone....
Old Nov 26, 2014 | 04:48 PM
abran's Avatar
Maybe the squirrels took them, Winter is coming...
There is a type of hinge system under the cowl at the front. Maybe its broken or something has come un done.
Old Nov 26, 2014 | 04:59 PM
Andy2Rover's Avatar
Thanks for the input Abran.....hopefully that's not it, but if tightening the nuts doesn't work that's where I'll look next
Old Nov 27, 2014 | 11:55 AM
Andy2Rover's Avatar
Turns out Abran was right. Took the cowling off (after removing the A-pillar covers), and found a bolt had fallen off the wiper linkage. Easy fix.
Now I have to fix/replace all the clips that broke removing the trim/cowling.
Also, looks like the linkage took out this ground strap that was hiding under there. Anyone know what the ground is for? Wiper motor?
Thanks!
Old Nov 27, 2014 | 04:53 PM
OffroadFrance's Avatar
It's a common problem when you remove the A pillar plastic covers. Being plastic it's a matter of luck whether they come off with breaking the lugs. Check it out with Paul Grant as he commented on these once before some time back. Drop him a PM and he'll no doubt advise or maybe supply some used trims. New LR ones with be a kings ransom no doubt.
PS Atlantic British have a vid on removing these covers.
tsuyoi
Sep 22, 2020 10:37 AM
caneraiser
Oct 27, 2012 07:35 AM
hubie
Jan 26, 2011 02:01 PM
jlwhite3
Nov 16, 2010 06:15 PM
