Wipers work but one isnt touching windshield
Old Dec 22, 2008 | 07:23 PM
JBEGIN's Avatar
Default Wipers work but one isnt touching windshield
On the Driver's side, or Left hand side... The wiper arm actually isnt hitting the windshield at all, ive cleared all ice from around the wiper arm, checked the spring inside, cant figure out why this is happening. One thing ive noticed tho is there is some play when i move the wiper arm around on the pin that holds it to the truck, could it be that i need to tighten that bolt up? Is there a way to adjust this or would i have to get a newer arm that isnt shot?
Old Dec 22, 2008 | 07:25 PM
JBEGIN's Avatar
Default RE: Wipers work but one isnt touching windshield
oh sorry i have a 99 disco 2...
Old Dec 22, 2008 | 07:29 PM
Pull the pivot cover, realign your wiper on the windshield and tighten the bolt with a socket.
Mike
Old Dec 22, 2008 | 07:36 PM
JBEGIN's Avatar
Mike
so the little button would come off, how would i realign the wiper?
Old Dec 22, 2008 | 08:33 PM
You realign the wiper arm buy moving it to where it needs to be, then using a 10mm socket tighten the nut.
Once you loosen the nut you can move the wiper arm a full sweep of the glass by hand.
Old Dec 22, 2008 | 08:41 PM
JBEGIN's Avatar
Okay ill try it. its pretty far out from the windshield so if it doesnt go close enough after tightening what should i do?
Old Dec 22, 2008 | 08:45 PM
Then I would look to see if the spring is broken, if you need to drive it you can switch the right hand wiper arm for the left hand one until you can buy a new wiper arm.
Assuming that tightening the nut doesnt not fix it, and I do not think it will.
Let us know how you make out.
Old Dec 23, 2008 | 02:08 PM
JBEGIN's Avatar
After tightening the nut down its better but still not exactly perfect... I neew new blades I cant be sure if theyve ever beenreplaced before...
earlyrover
Jan 15, 2017 12:45 PM
pvenuti
Dec 22, 2013 10:56 AM
TRIARII
ROAMING WITH FRIENDS
Jan 12, 2013 10:44 PM
bikeG976
Feb 3, 2010 11:35 AM
bobmarley123
Aug 12, 2007 07:36 AM
