Wiring in the rear cargo area
Old Sep 30, 2023 | 04:36 PM
JoshD's Avatar
Default Wiring in the rear cargo area
In the driver's side access panel in the rear of the vehicle is a plug with a green/yellow trace wire that is constant battery positive and a black wire that is ground. It doesn't appear to plug into anything I have optioned on the vehicle. Does anyone know what this was used for so I know what fuse it is using and also is there any reason why I cannot use this to connect to my little 12v socket/USB panel to run my Fridge while camping in 2 weeks? Thanks.
Old Sep 30, 2023 | 05:18 PM
mln01's Avatar
Have you checked the wiring diagram?
Old Sep 30, 2023 | 06:23 PM
Harvlr's Avatar
I think it’s there exactly for that purpose, but as min says, check the wiring diagram for the fuse size and make sure your draw will be less.
Old Sep 30, 2023 | 07:15 PM
JoshD's Avatar
Okay, I found a better electrical manual that has actual pictures of the connectors along with the color codes instead those worthless diagrams. It appears this connector C0691 is for rear A/C. Not sure why the yellow/green wire is always hot but atleast now I know where to start looking for the fuse. Here's a link. https://discoii.files.wordpress.com/...al-library.pdf
Old Sep 30, 2023 | 11:04 PM
gecko951's Avatar
I think rear ac is a 25A fuse so that should be plenty to run your fridge and usb charge port. Nice find because I also wanted additional aux power in the rear and re-purposed the rear cig adapter. I would make certain the fridge has a twist-lock connector that stays put because mine kept popping out so I cut that crap off and use XT60 connectors; another good option are the red/black 15/30/45A rated Anderson Power Pole connectors.
Old Oct 3, 2023 | 02:08 PM
greisinb's Avatar
I've got lots of auxiliary electrical stuff on my truck and I would HIGHLY recommend swapping out that 12V plug for an Anderson power pole connector (powerwerx.com, if you are looking for a good source). Those 12V "cigarette lighter" style plugs are notoriously loose stuff gets rattled loose all the time, they weren't originally designed as power interface plugs. I wouldn't want my fridge to get disconnected 30 minutes into a 4 hour trip!
greisinb
Apr 26, 2022 08:54 AM
cucch
Apr 18, 2022 08:35 AM
Westminster02
Build Threads
Mar 25, 2022 06:26 PM
za105
May 31, 2021 08:03 AM
raburrell
Jul 6, 2015 08:08 PM
