Wondering about a temp gauge going into summer.
Old Apr 19, 2011 | 10:12 PM
vandev's Avatar
Default try this one
ENGINE WATCHDOG TM2, Engine Overheating Alarm, Gauge & Sensor
Old Apr 20, 2011 | 09:40 AM
Disco_Fever's Avatar
Originally Posted by 0304Disco
The only bad thing about relying on the scan gauge or the ultra gauge is they are dependant on the factory sensors working correctly.
If your factory oil pressure or coolant temp sensor fails you are in the dark and don't really know what the status is and should shut down.
With using a seperate system you have the redundancy of separate transducers.
Lets say your oil pressure light comes on (This would never happen) and you look at your aftermarket guage and see that all is well, you now know your oil pressure switch is bad and you could continue driving. Otherwise your dead on the side of the road wondering if you really have pressure.
x2!!!! Having two gauges dependent upon a single sending unit has always seemed a little counter-intuitive to me.
Old Apr 20, 2011 | 10:20 AM
Snafu / Disco Fries's Avatar
I was thinking along the same lines about having separate gauges to really know. But, on the other hand, I'm thinking the Ultra Gauge type set up would have enough info to properly rule out a bad sensor, etc. For example, you see oil temps rising, you could quickly see the actual numbers of the coolant temps, oil pressure, etc. Sure as heck better than having nothing extra I suppose!
Old Apr 21, 2011 | 07:57 AM
longjon76's Avatar
Originally Posted by photocrimes
$24 Cheap *** elm327 bluetooth obd2 dongle and the Torque app for your android phone ($4.99). You get a full set of gauges, fault code reader, and you can set a temp alarm on your gauge so you get an audio alert when you are hot. It's pretty awesome.
Oh, and just FYI, you can configure the many screens any way you want. I have one whole screen dedicated to a digital coolant temp gauge. You have just about every thing the computer manages available. You could set up 8 mini gauges all watching fuel trim on each cylinder. Get realtime feedback on how your engine is running.
I have the same setup. It also handles all of the OBD functions, logged and pending faults... as well as clearing the drive cycle for inspection time. You can send a log of your driving sessions to email too.
To be 100% fair, sometimes the Bluetooth connection takes a dump and I have to restart the app. Of course, it does rely on existing temp and pressure probes so you are still stuck with hoping that they are functioning correctly.
Old Apr 21, 2011 | 08:08 AM
dcarr1971's Avatar
Wow, now that Torque app is pretty cool.
I might just have to pick up the bluetooth OBD2 adapter and fool around with it even if I install a set of temp and oil pressure gauges...
Old Sep 20, 2011 | 08:24 AM
slanginsanjuan's Avatar
Installing my glowgauge right now! Does the 1/8" adaptor fit in the receptacle for the coolant sensor or do we need another bit in between?
collin Barrows
Aug 8, 2011 09:33 PM
tweakrover
Oct 18, 2009 11:43 PM
LRDalltheway77
Aug 9, 2009 05:41 PM
flattrakker
Feb 10, 2008 01:51 PM
BIG g
Jan 31, 2008 12:58 PM
