Wondering a bit
Old Jan 2, 2015 | 03:50 PM
  #21
cybercop's Avatar
check ball joints and everything else I could find under the truck. Either I am the weakest man in the world or nothing is moving. I shook the tires up and down, left to right so hard I though I was going to knock it off the jack. also, got a crow bar in there the best I could without tearing up the boots worse than they already are and nothing moved.
I noticed a LOT of gunk build up on the power steering box and it was wet on the top. When I had my wife turn left to right real quick, everything moved together, but there did seem to be catching a bit on the bottom side of the box where it connects to the new terrafirma drag link (I think that is what its called).
Everything above the box where all the rods are splinned together and connected into knuckles seemed to all move together pretty well.
Going to adjust my tire pressure to 36/40. Was at 32/36. Maybe that will make a difference.
Maybe this is just how it feels after lifting a bit and putting on bigger tires.
Any other ideas?
Old Jan 8, 2015 | 01:11 AM
  #22
cybercop's Avatar
Would you guys than that caster correcting radius arms would be the answer?
The truck only has a 2" lift!
calebbo
Dec 15, 2010 09:03 AM
tweakrover
Oct 18, 2009 11:43 PM
LRDalltheway77
Aug 9, 2009 05:41 PM
flattrakker
Feb 10, 2008 01:51 PM
BIG g
Jan 31, 2008 12:58 PM
