Is it worth Having injectors cleaned
Old Feb 14, 2010 | 12:21 AM
Willie00d2's Avatar
Default Is it worth Having injectors cleaned
I have my heads off now for new head gaskets. Is it worth having the injectors ultra sonic cleaned and flow tested?
Thank you,
Willie
2000 Discovery II
181,000 miles
Old Feb 14, 2010 | 07:28 AM
No, not unless there was a problem before.
Old Feb 14, 2010 | 11:01 AM
I agree, if you want to help your engine, when it is all back together buy a can of B&G's 44K and it will clean up anything that is carboned up.
Old Feb 14, 2010 | 11:33 AM
Mrmerlin's Avatar
usually adding a bottle techron to the gas every 10 th tank keeps the injectors clean and also the valves.
For the cleaner to work best its better to do short drives this gives it time to soak in and thus remove more deposits, consider an oil change after this treatment.
Old Feb 14, 2010 | 12:40 PM
Willie00d2's Avatar
Thank you guys, thats alot cheaper then having a shop do it. I'll put that money towards some lift springs instead. I already have the OME shocks.
Willie
Old Feb 15, 2010 | 10:50 AM
Which OME springs are you going to be buying?
Old Feb 15, 2010 | 12:45 PM
brianb883's Avatar
Don't mean to thread jack, but is there any reason the injector O-rings would need to be replaced? Mine runs fine but I had the whole thing torn down for head gaskets and wondered if it would be a good preventative maintenance idea to change the injector o-rings.
bikeG976
Nov 28, 2010 12:32 PM
Disco Den
Mar 27, 2010 09:10 AM
Alex J
Jan 12, 2010 07:54 PM
brianb883
Sep 13, 2009 09:46 PM
EVN137
Jul 8, 2007 08:21 PM
