Wtf is going on with my windows?
Old Oct 12, 2017 | 01:09 PM
KingKoopa's Avatar
Default Wtf is going on with my windows?
Ok. Front passenger and rear passenger window have been inoperable.
Today I tore the rear apart, to find a bad switch and a bad motor. I already knew the switch was bad because the paddle was floppy, had no resistance. So I ordered a new switch. It's a front switch so I had to modify the plug to fit.
Get the new motor and switch it, window works great. Until I attempt to utilize the switch in the center consol. When I hit the center consol switch, nothing happens. If I hit it repeatedly I pop fuse #13 under the dash. Tried a different switch and same result.
So to summarize, both drivers side windows are fine. Passenger front does nothing. And passenger rear works fine with door switch but pops a fuse with consol switch.
Old Oct 12, 2017 | 02:46 PM
KingKoopa's Avatar
Just thinking out loud. Clearly there's a dead short.
Finding the shorted wire should be easy enough, I'll just probe the pins. But aren't the windows controlled through the bcu? What circuit is #13 fuse protecting if not the bcu?
Old Oct 12, 2017 | 11:26 PM
LR03NJ's Avatar
Try holding the switch up or down while pinching or moving the rubber harness cover between the door and the pillar or any harness while the panel is out. Mine broke again and it stayed halfway up just today and wont go up or down until I opened the door and held the switch up and played with the accordion rubber wire cover and the window went up. Just might work. Now I know the wires on the door broke again.
TATZOO
Jun 10, 2013 05:22 PM
bulldozer32
Mar 9, 2010 07:52 AM
samsly
Mar 24, 2007 05:23 PM
GrnRover
Feb 8, 2007 02:41 AM
cassie11
Aug 31, 2006 01:46 AM
