WTH: Driver side O2 connector will not budge
Old Sep 21, 2014 | 07:00 AM
chicane's Avatar
Question WTH: Driver side O2 connector will not budge
I was able to disconnect the passeger side O2 sensor just fine but I cannot get the driver side connector to come off the metal mounting plate to save my life. It doesn't help that it is located in an impossibly narrow location. I am using a long tool to flip the connector tab up while using another tool to pull up on it....nothing. Any ideas?
Old Sep 21, 2014 | 08:37 AM
Jared9220's Avatar
There is a video on the AB website that might help. They show how they disconnect the O2 you are having a problem with at around 4:40 in the video. I hope this helps.
Oxygen Sensor Kit - Land Rover Discovery 2
Old Sep 21, 2014 | 08:56 AM
MetalMarine's Avatar
i had to use two flat head screw drivers. used one to push locking clip. and while i had that lock depressed. I used the other screw driver to push up on the botton of the connectors.
its a pain to get the drivers side.
Old Sep 21, 2014 | 10:53 AM
chicane's Avatar
Thanks for the help I managed to get it off. Corrosion on that plate....unreal.
post42
Sep 10, 2013 03:33 PM
ruffram
Oct 20, 2012 12:12 PM
wheelgarage
Jul 6, 2011 02:09 PM
Princess
Sep 15, 2009 08:02 PM
handsome rob
Aug 25, 2009 12:30 PM
