XYZ switch
Old May 29, 2010 | 10:39 AM
njb8199's Avatar
Default XYZ switch
I did a search on the XYZ switch and read about a setting tool. Is this required for the installation of the switch?
Old May 29, 2010 | 01:52 PM
Rovin4life's Avatar
It should be used, if you still get intermittent no starts then its possible its issue.
Old May 29, 2010 | 04:23 PM
njb8199's Avatar
What exactly does this tool do?
The XYZ switch just looks like a plug and play item.
Is there a XYZ switch replacement guide w/ pictures anywhere on this forum? Do I have to go under the truck to replace it or can it be replaced with the console out?
Old May 30, 2010 | 10:57 AM
njb8199's Avatar
bump....
anyone know where I should replace the XYZ switch? from under the truck or by removing the console?
Old May 30, 2010 | 11:10 AM
Under the truck.
Old May 30, 2010 | 11:44 AM
njb8199's Avatar
Originally Posted by Spike555
Under the truck.
Thanks!
The RAVE .pdf wasn't too clear on that unless I was looking in the wrong place!
Old May 30, 2010 | 10:26 PM
mln01's Avatar
I had to replace the XYZ switch in my '99 DII about 5 years ago. The tool is used only to ensure proper positioning of the switch on the shaft, so that when the transmission is in Neutral the computer thinks it is in Neutral. The switch mounts over the selector shaft but can be rotated several degrees before the mounting bolts are tightened.
I found it pretty easy to align it correctly without the specialized tool. And if you find it is not aligned correctly you can just loosen the bolts and use the trial-and-error method until you get it right.
You definitely do this from under the truck. I did mine without raising the truck, but please be sure to chock the wheels well because you'll need to put the truck in Neutral to align the switch. You'll also need a small, 1/4" drive ratchet and 10mm socket due to limited space to get at the nuts. It's a really easy installation, but I recall the switch cost something over $200.
Good luck.
stu44mag
Mar 8, 2023 11:45 AM
meltdowndave
Nov 5, 2019 09:02 PM
meltdowndave
Apr 28, 2019 09:53 AM
RicknCody
Mar 28, 2010 07:49 PM
meltdowndave
Sep 26, 2009 11:18 AM
