xyz switch ?what and where is it
Old Aug 25, 2013 | 10:47 AM
from down under - XYZ switch fix - Australian Land Rover Owners
Old Aug 25, 2013 | 11:11 AM
Chrisinhouston's Avatar
moorebl, I believe you stated you had a 2004 model so I am pretty sure you will have the newer designed for this switch as I did in my 2003 Discovery.
Here is a link to my writeup if it helps.
https://landroverforums.com/forum/di...replace-59323/
And as Paul Grant stated the plug can be hard to get to and disconnect, so I used a slotted screwdriver to unclip it from the metal support tab on the transmission allowing the cable to drop down and for me to easily swap out the switches.
But I would suggest getting a complete diagnosis of your battery strength, assuring all connections are tight and not corroded and test your alternator as well before you buy a switch.
Old Feb 23, 2018 | 10:23 AM
Meldav32's Avatar
In particular - if M&S lights on, AND no CEL, that means tranny computer detected less than 9 volts. Time to check battery connections and good battery.
so if limp mode AND service engine soon light is on that can mean that it IS the XYZ Switch?
Old Feb 23, 2018 | 10:25 AM
Saturnine's Avatar
XYZ switch controls what you see on the dash in terms of what gear your in -- not sure if it has anything to do with limp mode
Old Feb 24, 2018 | 12:39 AM
number9's Avatar
Originally Posted by Saturnine
XYZ switch controls what you see on the dash in terms of what gear your in -- not sure if it has anything to do with limp mode :
Not Sure: x,y,z does much more than make symbols appear on dash.
Meld: It’s best to start a new post in the D2 area.
All indications you mention suggests but don’t mean it’s the switch.
Old Feb 24, 2018 | 03:54 AM
The Deputy's Avatar
Yes and No.
Get codes read and go from there. Code readers are dirt cheap anymore, or go to a parts store and have them read. Me, if you are going to own this vehicle for any length of time...buy one. It will help you describe the issue and related codes to us...enhancing the chances of us helping you quicker and more successfully.
Brian.
Old Sep 12, 2019 | 05:58 PM
JimDisco's Avatar
Default XYZ Position
Does anyone know whether you should make sure the gear that connects to the arm that shifts the transmission is turned all the way to the left or right when reinstalling after repair?
Old Sep 13, 2019 | 06:35 AM
mln01's Avatar
Do you have the RAVE workshop manual. If not you can download it from the link in my signature below.
According to the RAVE (page 622 of the PDF), when installing the XYZ the shaft should first be rotated fully clockwise (to the Park position), the rotated two clicks counterclockwise (to the Neutral position).
parksy
Feb 8, 2021 06:39 PM
EAustin494
May 7, 2019 11:23 AM
00OilLeak
Apr 1, 2019 10:58 AM
countryman
Mar 22, 2014 11:28 AM
Fairview
Feb 23, 2011 04:43 AM
