Yet another Disco not starting thread....
Old Nov 4, 2017 | 08:57 AM
The Deputy's Avatar
Originally Posted by dtmbinb
Hooked up my jumpbox. Still wouldn't turn over. No noise. Lights, radio, hvac all work. Bad battery? What should the voltage read for a good battery? Thanks.
A freshly charged battery will hold a surface voltage of about 12.7 volts (if checked immediately after charging and hasn't had an draw applied). A battery that has lost it's surface voltage, by just sitting or being used once or twice, will be 12.4 volts.
11.8 volts should give you some sort of cranking, granted slow and not for long, but should turn over your engine some.
Also, removed the starter on 03 without removing exhaust. Take a small pick and clean the allen head bolt before attempting to remove. And tapping the allen headed socket into the bolt helps too...it makes the allen seat deeply for best contact surface and helps shock the bolt some.
Brian.
Old Nov 4, 2017 | 09:55 AM
dtmbinb's Avatar
All done. Starts every time! Did not mess with the exhaust. Hardest part was fiddling with the heat shield. Good thing was when I had my new engine put in earlier this year all of that stuff was removed. The bolts had already been broken loose at that point. That definitely made it go smoother I think. Thanks for all the advice guys!
Old Mar 3, 2018 | 01:19 PM
Jane Lake's Avatar
5th Gear
Where do I get a coil relo kit for 99 disco ll, 4.0??? Thank you.
Old Apr 14, 2018 | 04:00 PM
OverRover's Avatar
This is the one you want, it's forum member Gerry's ( PM him @ LR03NJ ) kit.
> https://www.ebay.com/itm/Land-Rover-...JY2zXa&vxp=mtr
SinisterMoose
Jun 16, 2015 04:26 PM
clint70
Apr 19, 2015 10:35 AM
MU ///M3
Dec 2, 2011 04:13 PM
discobob
Nov 21, 2010 05:12 PM
whatmeworry?
Aug 1, 2009 08:23 AM
