zerk fitting and cross member bolts....
Old Aug 17, 2010 | 10:03 PM
agthird's Avatar
Default zerk fitting and cross member bolts....
the zerk fitting on the front of the rear drive shaft broke off does anyone know if it's replaceable?.....also need new 10mm bolts for the cross memeber at the tranny /transfer case they are rusted on i already broke two heads off,,,do you think atlantic british would carry these parts?...peace..
Old Aug 17, 2010 | 10:06 PM
Bundu's Avatar
Banned
Zerks are zerks, get some at your local auto store.
Get new grade 8 bolts and nyloc nuts at an auto store or Home Depot.
Old Aug 17, 2010 | 10:13 PM
lordmorpheus's Avatar
I don't remember if the zerks are SAE or metric. You might want to remove one from the front driveshaft to take with you to the local parts store to make sure you get the same size (it may save considerable frustration).
x2 on graded bolts from a hardware store.
Old Aug 18, 2010 | 08:41 AM
agthird's Avatar
okay thanks guys....
Old Aug 18, 2010 | 10:14 AM
antichrist's Avatar
Originally Posted by Bundu
Zerks are zerks
No they are not. There are many different thread specifications, styles and shapes.
The propshaft zerk fittings on the slip joint are 1/4-28UNF
Old Aug 18, 2010 | 01:31 PM
agthird's Avatar
okay Tom do you have a source that sells them?
Old Aug 18, 2010 | 07:14 PM
I bought mine from O'Reilly Auto parts.
Old Aug 18, 2010 | 08:00 PM
antichrist's Avatar
You should be able to find them at most auto parts stores
Old Aug 18, 2010 | 10:15 PM
agthird's Avatar
thanks Tom
abran
Sep 8, 2014 08:03 PM
bcmouser
May 9, 2014 02:04 PM
ebg18t
Dec 24, 2011 03:51 PM
Disco2Guy
Sep 26, 2008 12:33 PM
Disco2Guy
Jun 16, 2008 07:15 PM
