Discovery Sport Talk about the new 2015 Land Rover Discovery Sport
Camera System Fault
Old Sep 6, 2016 | 03:11 PM
TKP's Avatar
TKP
Default Camera System Fault
Hello Disco Owners,
Have a 2016 Discovery Sport with 5K miles so far and keep getting the annoying Camera System Fault intermittently! It used to happen only when I would start the car. Initially I didn't bother much as restarting the car would fix it.
But now it is happening while driving and I keep getting the warning in the instrument cluster. Pressing OK just clears the warning and restarting isn't fixing it anymore. But again it is intermittent, doesn't happen always.
Has anyone else experienced the same ?
Called in for an appointment with the dealer tomorrow, will update the outcome.
Old Feb 11, 2020 | 07:31 AM
Brandon Bannister's Avatar
What was the resolution? Having the same issue with mine.
Old Feb 13, 2020 | 12:14 AM
TKP's Avatar
TKP
The dealership tried to reset the camera system and flush out any codes in the vehicles, but the issue kept coming back. Finally they replaced the camera which resolved the issue. Had to get the vehicle in a couple of times to get it sorted out. Since my vehicle was still under warranty, all of it was free.
Good luck with getting yours fixed.
Old Mar 31, 2021 | 12:06 PM
Daro's Avatar
Brandon, I am also having the same issue (2016 RR) with the camera error. Was yours resolved by replacing the camera(s) as well?
TKP: How many cameras replaced? If one, location?
Old Mar 31, 2021 | 12:08 PM
Daro's Avatar
BTW, I am also getting "Limited SOS Functionality" error msg. Any ideas for resolution?
Old Apr 8, 2023 | 06:01 AM
Manuel HS's Avatar
Default I have the Solution about this FAULT
EASY SOLUTION [ Camera system failure ] JAGUAR XE XF ⚠️ Solution to the FAILURE in the camera system in Jaguar cars ⚠️ ✅ The issue of cameras is easily corrected ✅ In this case it is in an XE perl the solution is easily extended to any vehicle XJ XK F pace E pace F type etc ➡️ Tell us if you ever had that problem and how you solved it 👍🏻 Give it a like 👍🏻👍🏻👍🏻 jaguar xe camera #jaguar #xe #xf ☝🏻 subtitles if you don't know spanish friends
Old Apr 8, 2023 | 10:49 AM
Canuk's Avatar
The above poster is posting same thing on several forums,,,spammer?
Disco41989
Sep 12, 2019 03:12 AM
Damiphilips
Aug 4, 2018 11:02 AM
merlinj79
LR2
Dec 12, 2017 07:11 AM
Mark Davis
Feb 8, 2016 01:36 AM
