Discovery Sport Talk about the new 2015 Land Rover Discovery Sport
No crank no start discovery sport 2019
Old Nov 4, 2024 | 05:40 AM
ionut530's Avatar
3rd Gear
Default No crank no start discovery sport 2019
I have this discovery sport 2019 , no crank no start , ignition turns on and the car lock and unlocks but i have no communication with :
HVAC Front Controls Interface Module 'B'
GSM Gear Shift Module
PDM Passenger Front Door Module
DRDM Driver Rear Door Module
DDM Driver Front Door Module
VIM Steering Column Control Module
here are the codes
U0001-87 High Speed CAN Communication Bus - Missing message
U0001-81 High Speed CAN Communication Bus - Invalid serial data received
U0028-87 Vehicle Communication Bus A - Missing message
B100D-64 Column Lock Authorization - Signal plausibility failure
U3002-81 Vehicle Identification Number - Invalid serial data received
U0055-87 Vehicle Communication Bus D - Missing message
B1D35-23 Hazard Switch - Signal stuck low
B134E-14 Switch Illumination Adjustment Control - Circuit short to ground or open
B1219-15 Interior Boot/Trunk Release Switch - Circuit short to battery or open
B1087-87 LIN Bus "A"
- Missing message
U1A00-87 Private Communication Network - Missing message
U2008-54 Sensor Cluster - Missing calibration
P0500-29 Vehicle Speed Sensor "A" Circuit - Signal invalid
U0402-00 Invalid Data Received from TCM - No sub type information
U0121-87 Lost Communication With Anti-Lock Brake System (ABS) Control Module - Missing message
File Type: pdf
Old Nov 4, 2024 | 05:42 AM
ionut530's Avatar
3rd Gear
The car shows steering column locked but the steering column module is ok i have 3 of them
jbullock78
Oct 16, 2024 10:34 PM
Rufflyer
Aug 12, 2019 07:45 AM
Atticus_6147
Jun 5, 2019 03:24 PM
bluetick
Jan 6, 2019 08:31 PM
