Pre-purchase questions ‘16 Disco Sport
Considering becoming the owner of a 2016 CPO Disco Sport HSE (I’d be third owner) with very low miles and hope you guys can reassure me on a couple of issues:
1) Does the CPO follow the car? I’m sure this is the case, so since this ‘16 wasn’t registered until June 2016 - then my 7yr/100k mile warranty runs until June 20-23?
2) The car looks well maintained and is exceptionally clean. It does emit a fairly strong burning oil from the engine compartment and then into the cabin after warmup. I’ve seen this kind of thing be as small as an oil cap, or as big as can be imagined. Is this a common complaint/issue? I’d assume the CPO would cover just about anything engine or tranny related, so should I be concerned?
3) Any other common issues to look for? It appears that everything works otherwise.
Thanks.
Thanks.
I am in the same boat. Looking at at 2016 LR Discovery HSE.
My question is can I fit 16 inch wheels over the brakes? If not what is the smallest wheel it can fit? I know 18s come from the factory but I have 16 studded tires for winter that would be great to be able to use..
Thanks
Thanks
drewguy
May 23, 2017 03:15 PM
