Engine & Internal Chat about beefing up your engine's insides here.
engine modds
Old May 18, 2015 | 09:14 PM
  #31
ihscouts's Avatar
If I had a leaking oil cooler line I'd be plugging em off to get me home. I'm sure it would have no short term effect until new lines are made......
Old May 19, 2015 | 06:15 AM
  #32
dusty1's Avatar
Originally Posted by ihscouts
I doubt it, I think USnO used 4.6 rods otherwise the slugs would be a wee bit proud of the deck...... Now if you used aftermarket you could find a pin closer to the top like in a flat top but then you'd have one tiny chamber and it would probably eat composite hg's like Moon Pies at a Mobile Joe Cain Day Mardi Gras parade.
Oh I got ya. I thought he used the long rods..... I did the same 4.6 rods with 4.0 piston heads on the 4.6 crank.
Old May 19, 2015 | 07:03 AM
  #33
TOM R's Avatar
Scouts is saying you can't use 4.0 rods on 4.6 crank, stroke would be too long
Lost my rave on tablet trying to redownload ugh
Old May 19, 2015 | 07:33 AM
  #34
dusty1's Avatar
Got it... Yeah 4.0 Pistons with 4.6 crank and rods is the ticket
Old May 19, 2015 | 11:49 AM
  #35
USNAVYORDNANCE's Avatar
Yes you are correct. I should've elaborated more. I re-used my 4.0 push rods.
Old May 19, 2015 | 11:53 AM
  #36
dusty1's Avatar
That was my confusion
Was thinking you used 4.0 con rods.....not push
Old May 19, 2015 | 11:56 AM
  #37
Yeah my bad. Thought that was self explanatory.
Attached Thumbnails engine modds-11015116_810320025683036_3517105007462548605_n.jpg
Old May 19, 2015 | 12:04 PM
  #38
TOM R's Avatar
Oil pump seems fine with feeler gauges, should I put assembly lube on pump gears?
Old May 19, 2015 | 12:10 PM
  #39
TOM R's Avatar
Connecting rod bolts:
Stage 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Nm 15 lbf.ft
Stage 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Further 80 degrees
What's further 80* ?
  #40
dusty1's Avatar
Yes or Vaseline ...as long as it is oil soluble. Pack it full
