Engine & Internal Chat about beefing up your engine's insides here.
engine modds
Old May 20, 2015 | 07:19 AM
  #51
drowssap's Avatar
come on you going to cheap out over $60 in oil? what did your rod bearing cost $60<>, main bearing $60<>, timing chain & gears $60<>, oil pump?. see the point. why chance it for for the price of a good oil change. if you reusings the old cam and lifters no need to add zinc or give it a 30 minute break in.
Old May 20, 2015 | 10:15 AM
  #52
USNAVYORDNANCE's Avatar
I use lucas oil additive on all my scoots and rigs. Good oil.
Old May 20, 2015 | 01:21 PM
  #53
TOM R's Avatar
Reusing came and lifters
Old May 20, 2015 | 01:36 PM
  #54
I did the same. no issues. she started off as a shooting/offroad rig but she's become a DD now. My other vehicles and Harleys have been neglected... She's just so fun and nice to drive
Old May 20, 2015 | 06:59 PM
  #55
EricTyrrell's Avatar
Dino oil with Red Line Engine Oil Break-In Additive. Synthetic oil can lead to glazed cylinder walls during break-in, plus you'll be changing it often anyways.
Old May 21, 2015 | 01:35 PM
  #56
TOM R's Avatar
Originally Posted by dusty1
Most just mark the bolt head to get the degree (mark at 12 o'clock stop at 5)
Or you can get a dial attachment
Mark at 12 and stop @ 5 o'clock is almost 180 *
Wouldn't 80* be start at 12 and stop at almost 3 o'clock ( 3 is 90*)
Old May 21, 2015 | 03:18 PM
  #57
dusty1's Avatar
Good call. You ought to see me, I look even dumber than I sound .
Old May 21, 2015 | 03:59 PM
  #58
TOM R's Avatar
Must be all those cats
Old May 22, 2015 | 11:35 AM
  #59
TOM R's Avatar
Well engine is reassembled, waiting on a second set of hands to set it back in so I can bolt her up
Got the vale job done I neglected when I did the hg last year, heads were checked and did not rewarp so no cutting this time , guides were still good and so valve job was not too bad since everything was reused and I had the seals
Old May 22, 2015 | 03:23 PM
  #60
ihscouts's Avatar
Are you gonna be able to run it today once it's all back together?
