Engine & Internal Chat about beefing up your engine's insides here.
Low oil pressure
Old Mar 28, 2006 | 06:19 AM
brooksn's Avatar
Default Low oil pressure
re : 1987 LAND ROVER LR 90 DEFENDER
When driving the oil pressure is ok but on idle its about 5 to 10 on the gauge - the bottom end sounds ok ? Is this a major cause for concern ?
Many thanks
NB.
Old Apr 16, 2006 | 11:26 AM
headman's Avatar
4th Gear
Default RE: Low oil pressure
The drop in oil pressure at idle is typically due to increased rod and main bearing clearance.
Extra clearance due to wear in the oil pump housing will also create this situation.
At higher engine speeds the pump moves enough oil to maintain pressure dispite the wear.
The engine may operate like this for extended periods.
Replacing the pump may postpone the needed rebuild.
Old May 18, 2006 | 03:23 PM
You need to do a mechanical oil pressure test to verify the real pressure numbers, then you might consider doing a good engine flush to see it it will improve, if that doesn't help, pull the oil pan, clean and inspect, especially the oil pick up tube that are known to plug up.
Mike
rewi9d
Apr 12, 2012 06:12 PM
eaglewing
Apr 16, 2011 11:06 AM
tito5590805
Oct 4, 2010 09:11 AM
DooDer
Jan 12, 2010 10:46 PM
kpmaho
Feb 23, 2005 04:39 PM
