MSD DIS-4Plus Dizzy delete
A few years ago MSD had a system where you could do a total "Coil Per Cylinder" aka a distributorless system. However I guess to lack of interest they discontinued it??.... I've found other means of making a distributorless system by utilizing some other components; However I haven't totally built the system.
You have a 6AL-2? How were you going to wire that?
This link has the old MSD distributorless system. "scroll down"
For Sale - C&M Performance
I made a video of my MSD 6A, 8910 tach adapter, 8680 Timing timing retard or advance.
I haven't looked into the wiring yet. Got the 6AL2, blaster coil, and tach adapter all new for like $200.
So what other components are you using? I'd be interested in losing the dizzy, not so much on the water (not now anyway ).
Thanks!
Thanks!
I Haven't built the Distributorless system yet. When I was building my MSD 6AL I was stuck with alot of questions, so I wound up just building off of my existing system...keeping the dizzy.
Now that I have some more research and understanding I'll go back and build up a system. MSD, Holley and some other companies are making distributoerless systems.
The major hurtle you have to cross is the timing "when to spark/inject"....Like "IHscouts" said at the beginning of this forum.
Basically I haven't had the time to play around the crank triggers or timing curves.
Let me know if you know any other clues to this puzzle.
I'd say you got on helluva deal on your parts there fish!
The adjuster will allow you to run regular pump gas or tune for the trail. Not a bad thing really for a 4X4 that gets used. Is it gonna be your daily? The reason I ask is because you can adjust for the best fuel mileage. It's not vital that you have it but it's worth the trouble to install it.
You guys have to keep the guts of a dizzy to turn your oil pumps, that's why I showed the pic. The guy running that setup was tuning with a MegaSquirt pro box (pre-tuned) and raced his RV8 MG on weekends. I wouldn't think it's too far out on a MSD setup. Trigger mounted to the crank damper/pulley for a SB Buick.
So now the question is do I just run a stock distributor or try an upgrade??
If you watched my video you would have noticed that I still used my stock dizzy. you have to consider a few things...
reliability
performance
your mechanical ability
and other things...
The way I have the system set up is for reliability and performance.
For any reason the MSD system fails I can swap back to the stock wiring and get myself out of the woods. "with only a few wire swaps" If you got a performance dizzy you wouldn't be able to do this because you are 100% relying on the MSD system to NOT fail. T
The MSD system doesn't like to talk to the ECU "a voltage fluctuation that I figured out" so if you loose your aftermarket dizzy or any component in the MSD system...your screwed.
I'll post another video this weekend of my system "update". Ill try and explain my timing retard and dizzy and compare it with a stock rover.
reliability
performance
and other things...
Since this will be on a dedicated trail truck reliability and ease of trail maintenance are key. So I'll be sticking with the stock Dizzy then. I'll also be setting it up so it can easily be reverted back to stock as you have done and as seen in this other video.
Thanks for your help with this!
reliability
performance
and other things...
reliability
performance
and other things...
