How do I remove the dizzy?
Old Oct 29, 2013 | 12:49 PM
johnboy68's Avatar
Default How do I remove the dizzy?
I can't figure out the trick to get my distributor out of my 1995 Disco I.
I can see the bolt that I think I need loosen but I can't get to it with a wrench or a socket.
Any help would be great.
Old Oct 29, 2013 | 01:11 PM
antichrist's Avatar
You remove the clamp bolt, clamp and spacer then pull out the distributor. Be sure to mark the location of it before loosening the clamp.
Old Oct 29, 2013 | 01:13 PM
johnboy68's Avatar
That's the problem. I can't get anything on the clamp bolt. It's situated in such a way that it seems impossible to get a wrench or socket on.
Old Oct 29, 2013 | 07:51 PM
ihscouts's Avatar
Hmmm, wanna remove the dizzy and can't figure out how, sounds like a win/win situation to me. I don't even wanna ask why your removing it in the first place.......
You know why GOD invented the "Distributor Wrench"? So you'd call him by his correct last name - Almighty and not the one you've been using.
Old Oct 29, 2013 | 08:09 PM
johnboy68's Avatar
Let me clarify for you...
I know how to remove the dizzy, I don't know how you're supposed to get to the bolt.
Is there truly a distributor wrench?
As to why I want to remove it is of no consequence to the question. Maybe I want to adjust my timing, maybe I need to work on it, maybe I just want to throw it over the hill so I never have to work on this over temperamental vehicle again in my life.
Old Oct 29, 2013 | 08:12 PM
johnboy68's Avatar
Just googled distributor wrench. There is such a thing. I've removed plenty of distributors in my life, never needed a special wrench. Now to go find the correct one...
Old Oct 30, 2013 | 04:30 AM
antichrist's Avatar
I can't remember the size, but I'd get a set of crowfoot wrenches, they'll come in handy for other things. Probably a set of flare nut crowfoots would be most useful.
Old Feb 21, 2021 | 11:47 PM
LipLounge's Avatar
Old thread, but just removed mine with a 9/16 wrench (spanner). It is a tight fight and the radiator fan regularly got in the way. A ratcheting wrench would be ideal.
lrnoob
Mar 7, 2022 06:31 PM
DISCOVERYIIG4
Sep 5, 2016 04:47 PM
revel8or
Apr 8, 2014 07:47 PM
parkerlander
Feb 18, 2014 10:26 AM
cplthomas
Oct 10, 2008 03:37 PM
