Engine & Internal Chat about beefing up your engine's insides here.
Will Buick 215/300 camshaft work in 03 4.6L?
Old Aug 14, 2013 | 02:20 PM
C.O.R.E.inMinnesota's Avatar
Default Will Buick 215/300 camshaft work in 03 4.6L?
I need to build a new motor for my D2 and want better perf.
Old Aug 14, 2013 | 04:22 PM
jafir's Avatar
With some modification.
Old Aug 14, 2013 | 04:23 PM
D&D Fabrications: Engineering & Fabrication Services
Old Aug 31, 2013 | 07:26 AM
No, the 215 cam had a distributor drive gear not needed on the Rover engine.
Old Aug 31, 2013 | 08:14 AM
acamato's Avatar
Crower makes a few of cams(50229, 50230) that will work in a DII motor with some mods. They are not machined for the retaining plate. Some say you don't need it because the timing chain will hold it in place. See below for some other machining that needs to be done.
From another forum
The front snout has to be machined off, drilled, tapped and new keyway machined at just under 90 deg to the left. In other words the Crower distributor cam has a keyway at 12:00 and the GEMS/Bosch cam is almost at 3:00.
D&D sells a kit with the cam already modified.
Old Oct 18, 2013 | 03:05 PM
95RoverLWB's Avatar
I have the Crower 50229 in my 95 Classic, when I was looking for cams I did find cams for the 4.6. Try looking under other names/ email the manufacturers/ companies.
Crane cams are also very good cams, almost got one for my rover. they can custom grind one for you. About $250 for my rover.
bobalou
Engine & Internal
Jun 10, 2015 01:29 PM
ryanD2
May 14, 2009 04:22 PM
scadjoey
Jan 9, 2008 11:19 AM
4x4poland
Nov 21, 2006 08:40 PM
masher
Dec 31, 2005 09:56 AM
