Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Discovery 2 LS Conversion
Old 03-27-2023, 11:38 AM
Jlutty3's Avatar
Where is ACEngineer on this? I don't mean to call a guy out. I'm just curious about his input.
  #1372
Old 03-27-2023, 01:11 PM
One of the other forum members provided a quote from ACE after asking the same questions. I can’t remember the exact words, so paraphrasing ACE, the Rover MAF signal is used by the transmission. Kinda vague.
I have emailed ACE and have found them, or him, to very responsive. Might be another opportunity to loop them, or him, into the conversation.
  #1373
Old 03-28-2023, 07:37 PM
04disco2va's Avatar
Hi All
Sorry dont mean to change the MAF discussion. My LS swap is almost completed. Need some help, cant seem to get a full open throw on the throttle. Using a Summit intake and throttle body (92mm). Tried 2 different throttle cables recommended by Summit Racing. Everything fits with no play in the cable but only getting 1/2-2/3 open. Has anyone run into this issue ?
  #1374
Old 03-29-2023, 05:42 AM
Boostle's Avatar
Originally Posted by 04disco2va
Hi All
There's a few issues with this setup. The size of the TB pivot assembly is much larger than stock so the amount of throw is different. The distance that the TB mount also has to be moved back - a custom mounting solution will be needed. Lastly, the pedal geometry/throw is most likely different. I had to remove all the stops on the pedal assembly and cut away some of the carpet to get extra throw. With all that done I still only get about 85 percent of max throw. I'm happy with that for now until I figure out further improvements.
  #1375
Old 03-29-2023, 06:44 AM
04disco2va's Avatar
Thanks Boostle. Appreciate all the help with my many questions !!
  #1376
Old 03-29-2023, 08:51 AM
Yes! I did run into this exact problem. You need to remove half of
the GM style throttlebody cable wheel and replace it with the stock Rover throttlebody wheel. The Rover wheel is smaller, so the stock Rover cable travel results in the GM throttlebody opening all the way.
I used a Dremel tool to grind off the rivets of the GM throttlebody wheel, and removed the outer half, which gave me a flat spot that I could weld the Rover wheel to. Next, I welded the GM cruise control post to it. It’s not real pretty, but works good.
  #1377
Old 03-29-2023, 09:04 AM
Boostle's Avatar
Nice, I'm going to have to do this.
  #1378
Old 03-29-2023, 08:37 PM
04disco2va's Avatar
Thanks Tracecollier. Nice idea to make that work ! I need to learn how to weld !
  #1379
Old 04-01-2023, 08:48 PM
04disco2va's Avatar
Hi All. Engine swap progressing. Checked all connections and hooked up battery to do a couple of cranks. Dash lights stayed on after key was turned off. Specifically, brake, oil, hill decent, service engine, trip/odometer light. Had to disconnect battery to get them to turn off. When reconnected battery they did not come back on. Any ideas what I hooked up wrong? Thanks for any help as always.
  #1380
Old 04-02-2023, 03:54 PM
CaptainAaron's Avatar
Possible bad ground connection. I would wait until everything gets connected / you are ready to run before troubleshooting this further. It could be circuit feedback from something not hooked up, etc.
Quick Reply: Discovery 2 LS Conversion
