Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Discovery 2 LS Conversion
Old Jan 7, 2019 | 07:31 PM
  #191
robert.juric's Avatar
Sounds great. What are your ideas for an air box?
Old Jan 7, 2019 | 07:32 PM
  #192
Saturnine's Avatar
Old Jan 7, 2019 | 08:03 PM
  #193
Nosugar0carbs's Avatar
Great progress. ^ Maybe for the airbox a 90* bend next to the intake plenum, looks like plenty space
Old Jan 7, 2019 | 08:54 PM
  #194
ACEngineer's Avatar
With the first Disco, we had to curve around the A/C compressor and then back into the factory box. It worked okay with a good filter. Cheap filters were too restrictive at high RPM. A 90 won't work because of the fan. Since this is my personal rig with a snorkel, we're going to figure something else out. We're probably going to go with a 4 inch inline filter plumbed directly to the snorkel. Might also do an electric fan since the wiring is already in place for it.
Old Jan 7, 2019 | 09:37 PM
  #195
CollieRover's Avatar
‘05 Pontiac GTO fans fit well with trimming. As far as I can tell that will give you the most fan you can get on the radiator. A 14” and 12”. I used a Ron Francis AR99 Controller works great.
Old Jan 8, 2019 | 10:08 AM
  #196
dgi 07's Avatar
Do you have a picture of the GTO setup? Trying to plan for when this comes online.Hopefully there is enough space with the GTO fan ?
Wouldnt need a controller with this swap as its still running the LS ECM
Old Jan 8, 2019 | 10:39 AM
  #197
https://landroverforums.com/forum/di...e-77141/page9/
Here is a link to the thread, not sure where th pics are now, if anywhere.
Old Jan 8, 2019 | 11:49 AM
  #198
dgi 07's Avatar
Based on your picture, it would be close to install a quick 90 right out the throttle body, but its possible.
Old Jan 8, 2019 | 12:13 PM
  #199
I couldn't say obviously, but without the upper fan shroud there is quite a bit of room. Honestly, my favorite part of the fan set up, aside from I think it is cool, is never having to take the damn viscous clutch fan off again.
I would be really interested to see what an all aluminum GTO Radiator would look like and fab it in. That way the fans would clip right in, or that is my impression. Unfortunately, I can't weld.
Old Jan 9, 2019 | 03:40 PM
  #200
ACEngineer's Avatar
Thanks for the recommendation on the fans CollieRover. Between your pictures and some rough measurements, it looks like that would provide enough space to do a 90 degree turn for the intake. One nice thing about the LS ECM is that it has programmable provisions already in place for two fans, which you can set to your preferred temps for turning on and off using HP Tuners or other software. I have been looking at getting a custom all-aluminum radiator for this setup and for off-road builds, but it'll have to wait until later.
