Discovery 2 LS Conversion
#801
If that's not the case then sure it'll run it but I wouldn't drive it in case some circumstance with the speed sensors and transmission creating an issue, why not just get it programmed first and not mess around with extra issues? I wouldn't be afraid to simply start it up though. The GM ECU will simply be running the engine it was made to run.
#802
My ECU is out for tuning....
I gave the sheet provided in instructions, he asked if VATS is to be disabled, the answer should be yes.
Then he asked further questions not on the instructions such as secondary O2 sensors being disabled, the answer is again yes but it's not in the instructions.
Is there anything else the tuner will need to do besides the instruction sheets items? Maybe we can get the instructions updated with these things but if we're going to make a change, let's get every detail.
-Greg
-Greg
The following 2 users liked this post by 05TurboS2K:
Matt Brown (07-08-2020),
whowa004 (07-08-2020)
#803
Yes, if there is enough interest. We've designed it to be completely bolt-on and something that an enthusiast could do in their garage. Fits into the factory motor mounts. Only welding should be connecting the cats to the manifolds or headers -- and a local exhaust shop could do that easy.
#804
I am in that dilemma. I'm looking for quality and good price. which are the best to mark in spare parts. bearmach, rockauto, atlanticbritish is very expensive and i don't think they are OEM
#805
[QUOTE = Sixpack577; 654161] Si no hubiera reconstruido mi 4.6, estarķa golpeando tu puerta con ganas de un kit LS, ”jajaja! [/ QUOTE]
#806
While this kit seems to be a great starting point there are an awful lot of unknowns still in the process and I'm concerned with the longevity of some of the components. That's just me being a skeptic and not having seen in person the motor mount and bellhousing solutions. I can't wait to see and hear how Greg likes his once he's rolling around again!!
#807
Every engine part and bearing has measured in spec, and the prices are cheap.
#808
#809
You can order online, but I always call.
They know their stuff, and what parts you need for any specific job.
They also give a good discount to forum members.
I can't say enough good about the parts and service that they have given me, and on multiple orders.
I have also ordered from AB, with no complaints, other than their high prices.
And, I did get a pair of Cruciform seals(go in rear main cap) from Bearmach, because they are the only place that I have found that sells the oem kind(Allmakes brand Cruciform seals are Not made the same shape as oem).
They are only a few bucks too, so no big deal.
Lucky8
716-898-8153
Lucky8
716-898-8153
#810
Lucky8
716-898-8153
Lucky8
716-898-8153
