Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Engine swap Series III diesel to 2,5L petrol - question about the distributor
Old Sep 30, 2022 | 04:12 AM
vdsouris's Avatar
Default Engine swap Series III diesel to 2,5L petrol - question about the distributor
Hi all,
I am swapping the engine of my series III, it originally had a 2.25 diesel which I’m replacing for a 2,5L petrol from a defender 90. Reason that it only has 45 kW and it needs a complete overhaul.
I am good on track, the old engine is out, and I am putting the last bits and pieces of the 2,5L petrol together before I install it.
Now the thing is: I am a bit stuck on the distributor. The 2,5L originally came with either a Ducelier or a Lucas distributor.
-I am wondering if these distributors are interchangeable?
-Does anyone know how you determine which distributor to fits your engine block?
The block (no 17H09…) came with a Ducelier but the engine also came fitted with the wrong receiver and exhaust manifold (2.25 petrol) so I don’t thrust that it is the right one.
Further I want to install an electronic distributor, I’ve compared the replacement model for the Ducelier and the Lucas (see pictures) and they are almost the same, so very hard to determine the right one.
Thanks for the help!
Joris
Ducelier replacement
one which came with the 2,5L block
Lucas replacement
landrover94000
Oct 13, 2021 01:35 PM
johnmm51
Defender
Oct 3, 2020 09:03 AM
Erikson
May 23, 2012 09:00 PM
PORKY1
Engine & Internal
Dec 5, 2007 05:28 AM
