Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
ZFHP24 Transmission Pump Gasket
Old Feb 28, 2023 | 02:12 PM
Jensen Vermont Stenberg's Avatar
Default ZFHP24 Transmission Pump Gasket
How hard is it to remove the pump and replace the gasket behind? I did not have enough pressure on the pump when I first pulled the housing (my fault). I was loosening a bolt and noticed I had lost an ounce or two of transmission fluid. Tightened it back down, re-cut my pipe, and it has not leaked since. I have a lingering concern that it make leak under pressure now if the gasket is indeed compromised. I haven’t been able to find any write ups or pictures of the process. The gasket is cheap and I’m not really intimidated by the job, but I would like to know what I’m getting into. Anything I’ve been able to come across says you can service the gasket and the first gear clutch pack without pulling the transmission? Pics and advice would be appreciated!
zeropegleg
Jul 25, 2013 09:27 AM
Colorado David
May 28, 2013 07:05 AM
cobbcj7
Jan 24, 2012 08:47 PM
Travelor
Dec 29, 2011 03:39 PM
willrok13
Jan 1, 2011 03:44 PM
