Forum Help & Suggestion Center This section is NOT for vehicle technical questions. This section is for problems or suggestions for the forum itself.
Gear Shift Problem on Landrover D2
Old Dec 8, 2013 | 09:39 PM
959's Avatar
959
Default Gear Shift Problem on Landrover D2
I have a 2000 model Landrover Disco 2, Turbo Diesel, Auto.
I am presently experiencing a problem whereby, especially from a standing start, with the gearshift in “Drive”, it seems to remain in second gear with the revs going upto as high as 3800. I then seem to have two choices – release the accelerator completely or kick down to make it change into 3rd and Drive. This problem does not manifest itself all the time but is intermittent. The Airflow meter was “suspect” and was replaced a week ago. No fault codes show up on the diagnostic computer. Transmission has been checked for “slip”, even uphill, and appears to be fine. Filter and T/fluid replaced periodically and as late as last week, but fault still persists occasionally.
Any help and advice much appreciated.
Thank you.
Tony H.
importdave
Sep 25, 2014 10:18 PM
Lee1140
Dec 1, 2009 10:17 AM
roving patrol
May 17, 2008 05:23 PM
rizzoz1
Feb 13, 2007 10:40 PM
disco1
Nov 10, 2005 01:14 AM
